GPC in about "Vybrid Reference Manual, Rev. 7, 06/2014"
893 次查看
soichiyamamoto
Contributor V
That's a question from a customer.
I will ask a question about "Vybrid Reference Manual, Rev. 7, 06/2014".
The following register is deleted by a manual.
・GPC_IMR2
・GPC_IMR3
・GPC_ISR2
・GPC_ISR3
Does it mean that I cannot use these registers?
Will it be explained in Errata?
soichi
458 次查看
jiri-b36968
Hi Soichi,
There is missing also GPC_PGCR and GPC_PGSR. Unfortunately description of those register is not present due to the mistake in final RM generation at documentation department. Should be corrected soon.
For you convenience - attached is the GPC chapter from RM v.5
/Jiri
459 次查看
jiri-b36968
Hi Soichi,
/Jiri
458 次查看
soichiyamamoto
Contributor V
Dear Jiri,
Thank you for reply.
I close the thred.
Bset Regards,
soichi
