support pairing and bonding with le security and without according to config QN9080
3,495件の閲覧回数
ghada2
is it possible to support pairing and bond with le security and without according to configuration, I started the initialization by setting the config to GAPM_PAIRING_LEGACY then changed the device  config to GAPM_PAIRING_SEC_CON and request the bonding, the stack always responds with disallowed command to set the device config to secure connection request, so is there aways to support both and choose during pairing
0 返答(返信)
