how to delete or move a question?
10,461 次查看
bowerymarc
the help for deleting and moving questions or topics is for the old site.  There seems to be no way for the originator to move or delete a question or post.
9 回复数
5,413 次查看
jambibambi
@Adrian Hi, I cant seem to edit / delete my post (there is only one)...?
9,678 次查看
edward65654
Hey @bowerymarc,
The following steps illustrate how questions can be deleted in your site:
create a new survey or select a survey to edit.
navigate to the question you want to delete.
hover on the question text and click on Delete.
follow these steps to move a question:
navigate to the question you want to move.
hover on the question text and click on ‘More’, and then select Move and the desired location where the question should be moved.
10,204 次查看
undefined
undefined
10,190 次查看
Adrian
Senior Contributor IV
Done, the post has been moved to the NFC forum
10,299 次查看
asiertapiazulai
Hello @Adrian:
I would also like to upgrade a question:
https://community.nxp.com/t5/LPC-Microcontrollers/FreeRTOS-stack-backtrace-is-disabled/m-p/1192190#M...
I would like to move it to the MCUXpresso IDE category.
Thanks a lot.
10,292 次查看
Adrian
Done.
10,444 次查看
Adrian
Hello @bowerymarc,
I can help you with the move changes.
10,410 次查看
bowerymarc
10,293 次查看
Adrian
Done.
