How to disable cache coherence on e6500?
1,474 次查看
janewhitman
I was wondering whether there is a way to disable cache coherence on e6500. I wouldn't like to turn off the caches completely. Any suggestions on this?
Thanks!
J.
标记 (1)
1,191 次查看
michelle
NXP Pro Support
NXP Pro Support
Coherence is a TLB bit (the M bit) which tells corenet to snoop caches and changes core behavior towards that region of memory to coherent (it impacts many instructions' behavior).  The caches themselves are a separate issue.  What are you trying to do?  Run with caches off?  Don't  Performance would be awful.  Run without a cohrenence domain for a memory region?  That might make more sense but goes quite off the reservation for the standard supplied SDK and other NXP reference software...
1,191 次查看
alexander_yakov
Please look e6500 core Reference Manual, Section 5.6.2 "Enabling and disabling the L1 caches".
Hope this what you asking for.
Alexander
1,191 次查看
janewhitman
Hi Alexander,
unfortunately, I cannot find anything related to coherence in that section.
However, I discovered TLB entry fields today, so I hope it's the right direction.
Thank you,
J.
