I'm interested in using the MMA8450Q sensor with development and communications board (RD3924MMA8450Q or LFSTBEB8450), but it important to know the dimensions.
Additionally I would like to know the exact implementation because I found ambiguous pictures on the website. Farnell show a low built type: http://nl.farnell.com/freescale-semiconductor/rd3924mma8450q/mma8450q-accelerometer-dev-kit/dp/1796119?in_merch=true&MER=i-9b10-00001460
which would be excellent for my application. Your website, however, shows a different (higher built):
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=LFSTBEB8450&fr=gtl
So I would like to know what are the exact dimensions and what does is look like.
解決済! 解決策の投稿を見る。
We have the following 2 option for this kit:
LFSTBEB8450: http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=LFSTBEB8450
LFSTBUSB: http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=LFSTBUSB
The board that you see on the Farnell link was a prototype board which is no longer manufactured. The reason of why we designed this development kit this way it’s due to the portability, you can use daughter (dip) boards from other sensors (MMA845x, MAG3110, etc) using the same USB and connectivity boards from this kit.
About the dimensions of these boards…
LSFTBUSB size: 47x54mm, height of 11mm
LFSTBEB8450 Connectivity board size: 32x32mm, height of 12mm
LFSTBEB8450 Daughter (dip) board size: 12x26mm, height of 10mm
*The three board assembled height is about 22mm
