I'm using MMA8451 - Can I permanently write settings to the sensor
1,474 次查看
davidgroff
I am using an Arduino Uno to write configuration settings to the MMA8451.  I have set it up to detect freefall and set interrupt pin 1.  I want to know if I can save these settings in non-volatile memory of the chip so that I don't need to re-write these to the chip every time power is reset?:
1,348 次查看
TomasVaverka
Hi David,
Unfortunately not. The non-volatile memory is not user accessible. The only way is to write the register configuration every time after powering up from your Atmega328 MCU.
Let me know if you have any other questions.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct" or “Helpful”. Thank you.
1,349 次查看
TomasVaverka
Hi David,
Tomas
