What is the time for the S32K1's power supply to rise to the RESET pin?
Hi @jingfang,
It depends on the power supply ramp rate:
Once VDDX reaches 2.7V, which is the Low Voltage Reset Deassert threashold, the MCU leaves the system reset.
In the datasheet, you can find these specifications:
Hello @danielmartynek
Thank you very much for your clarification. I have understood it.
But if can you tell me roughly, how much time it will take to jump to Application, when we normally Reset the MCU.
Actually I am achieving 4.22ms, for your kind reference I have attached Logic Analyzer image.
I hope you will correlate my doubts.
One more Doubts @danielmartynek
Will you clarify my one Doubts, on the Datasheet the Flash Timing Specification for (Program Section
execution time) (1KB flash) is 5ms.
So when the Micro-controller is Powered, does it is taking 5ms to jump into the Application Program?
For you kind reference I took snap from the datasheet. I hope you will check Flash Timing Specifications Image for it.
I hope to hear from you Soon
Nibesh
Hi @Nibesh,
Can you put it into a new thread?
This is not related to the subject of this thread.
