Sharing C/C++ Header Files With Assembly Source in IAR compiler
1,704 次查看
SreejithN
I tried to include S32k146.h header on a assembly file to get the interrupt vector address (S32_SCB->VTOR) But the compiler showing below error
Error[2]: Failed to open #include file 'stdint.h'
Already given included directives for assembler
标记 (1)
1 回复
1,615 次查看
jiri_kral
the C header file can't be used in Assembly code. If you like to get VTOR address you can simply read it from the register address - 0xE000ED08.
Jiri
