Hi, I was trying to burn the firmware to S32K116 EVB board via JFLASH soteware, but the connection failed while jflash was connecting to target. The error reported as follows
I used the SWD mode, in which some necessary pins are selected.
(GND, RESET,SWD_DIO,SWD_CLK)
What should 1 do for this problem ?
Any advice would be appreciated. Thank you.
Hi vanaua@163.com,
I would check if the MCU is powered (VDD) and all the SWD connections.
You could try to connect the J-link to the MCU using J-link Commander instead of J-Flash.
Or try a different debugger if you have it.
J-link/J-Flash are Segger products so you may contact their support as well.
BR, Daniel
