S32K344+QSPI Initializes
iverson3ya
I am testing QSPI with the flash model MX25L12833F. I am mainly referencing example code for configuration, but I am encountering an issue during initialization.
The value at the position #define IP_QUADSPI_BASE (0x404CC000u) appears to be empty and does not seem to be a valid value.
The program is unable to run properly.
Could you please assist me? Thank you.
davidtosenovjan
Could you tell which specific example is you question related to? Thanks
davidtosenovjan
iverson3ya
I have resolved the issue. I forgot to enable the QSPI clock.
thanks
iverson3ya
After entering this line, it immediately jumps to a Hardfault.
