S32K342 no J-link support?
towenyu
Previously I have worked on S32K344 part and everything went fine. Due to part shortage, in recent PCB I used S32K342 and suppose everything should kept same, except smaller flash memory.
I'm using Seggar J-link. With S32K342 new board: Memory access fail when connecting target. To exclude potential configuration issue, I build a new project from scratch and select S32K342 as device. And I found S32K342 can't support seggar as debugging interface -- while S32K344 can.
How could I create a S32K342 project with J-link support?
Thanks and Best Regards,
Yu Wen
Senlent
towenyu
Here is the S32DS version I'm using:
