S32K342 Pin and Port configuration mismatch error
948件の閲覧回数
bbaskii
Hi NXP Team,
I am configuring SPI example project in S32DS and wanted to change it to LPSPI1 and LPSPI2 so that it will help simulate my project environment. But when i configure it in Pin tool same pin number are not configured in peripherals-Port1 configuration. In Port1 configuration it is showing different functionality. Not sure what i am missing here. Please help me to fix the issue.
bbaskii
909件の閲覧回数
Senlent
Hi@bbaskii
Can you provide a screenshot? From your description, I don't quite understand what exactly is the error you encountered?
For the pins involved in the LPSPI1 module, you can find it in the appendix of the S32K3 data sheet, I will copy the content below for your reference.
S32K342_S32K342_S32K322_IOMUX.xlsx
3 返答(返信)
848件の閲覧回数
bbaskii
Thanks for the reply. My query got answered after reading the pin mux excel sheet.
bbaskii
890件の閲覧回数
bbaskii
Thanks for your reply. I found from the Reference manual attached pin mapping excel sheet. you can close this topic.
910件の閲覧回数
Senlent
Hi@bbaskii
