S32K3 sample code about SWT_Ip and Wdg.
StephenYeh
Hi Sir,
Would you share us about Wdg_Ip(Non-AutoSAR version) sample code?
danielmartynek
Hi @StephenYeh,
There is only the Swt_Ip non-autosar driver (example: Swt_Ip_Example_S32K344), because the MCU has the SWT watchdog module.
The Autosar Wdg driver calls the Swt_Ip driver (in Wdg_Ipw.c)
BR, Daniel
StephenYeh
Hi Daniel
I check the SWT and WDG from datasheet.
The WDG can support POC(Power -on Reset) but SWT don't support (POC), right?
This is why we need the sample code about the Wdg_Ip sample code.
danielmartynek
Hello Stephen,
The WDG driver is not a POR_WDG driver.
The WDG driver is an MCAL driver that configured the SWT module like the SWT_Ip driver does.
I have gone through the RTD drivers, but it seems like the POR_WDG does not have any RTD API.
