For flexcan module, lot of registers can only be read/write on Freeze mode.
for example,
Therefore, if you need to change the Flexcan reigster during normal operation, you should first see if you need to go into freeze mode.
Hi, Senlent
Thank you for your reply. I have one more question.
Are send and receive error counters automatically counted according to CAN2.0B specifications? Do we need code for any Settings?
