S32DS processor expect configure question
1,421 次查看
asd046012
Hello
      Now I use the processor to configure PIN, when I configure the pin PTE11,but the processor will auto refresh, and will show PTA configuration interface, so I want to configure the PTE port again, I should pull down the interface again. This is a waste of my time.
   Is there a Configuration option to put an end to this situation?
标记 (1)
4 回复数
1,402 次查看
Robin_Shen
Please try:
Robin
1,378 次查看
asd046012
Hello
      This is a temporary solution, I re-install S32 design studio, This situation disappeared.
       I didn't know why!
1,362 次查看
Robin_Shen
If this problem occurs again, it is recommended to record the screen and upload it to me, so that it can be reported to the IDE team to check the reason.
1,412 次查看
TomLightning
the processor creates two files named mux.h and mux.c. In this files it saves your pin configuration. If you have problems with the processor you can add a pin configuration in the mux.c by yourself (The example below shows two configurations... just copy one of them and change it for your purpose):
pin_settings_config_t g_pin_mux_InitConfigArr[NUM_OF_CONFIGURED_PINS] =
        .base          = PORTC,
        .pinPortIdx    = 1u,
        .pullConfig    = PORT_INTERNAL_PULL_NOT_ENABLED,
        .passiveFilter = false,
        .driveSelect   = PORT_LOW_DRIVE_STRENGTH,
        .mux           = PORT_MUX_AS_GPIO,
        .pinLock       = false,
        .intConfig     = PORT_INT_EITHER_EDGE,
        .clearIntFlag  = false,
        .gpioBase      = PTC,
        .direction     = GPIO_INPUT_DIRECTION,
        .digitalFilter = false,
        .base          = PORTE,
        .pinPortIdx    = 0u,
        .pinLock       = false,
        .gpioBase      = PTC,
But be sure, that the definition of
NUM_OF_CONFIGURED_PINS = 0x02U
 in the mux.h file matches the number of pin configurations in the array above.
Tom
