Just started working on NXP.
facing some issue in flashing and debugging the code to this EVB .
all other board are working.
IDE : Design Studio for ARM
I am trying to program the S32K146EVB by using openSDA and also with the J-Link debugger
This error pop up.
the RED and Green LED's are always ON .
also tried on MATLAB example same error comes.
Hi @VaneB just tried that method,it not working.
I'm using this EVB for the flashing the code via Embedded coder of matlab and since we are not able to flash the code. so I am trying it on design studio. trying to flash example code. as per your provided link same pulse are received on that point.
Hi @PU1
Please refer to S32K144 in permanent reset.
Also, could you provide me with the following information?
B.R.
VaneB
