Port Pin Configuration Error in Peripherals
NadipalliLTTS
Hi Team,
Currently We are working on Port pin configuration of S32K312 in S32 Design studio 3.4 V
While configuring pins i am getting Peripherals error While clicking on Update Code button, it was showing as error as below. can someone help how to proceed here, in order to fix this error. While updating the Pin configuration we have tried in two ways. One way is we directly updated the pins in Pins section. the second way is we directly opened Peripherals tool. in Both configurations it was showing the error. Kindly help how to proceed here. Peripheral_error.jpg
Robin_Shen
There are a lots of MCAL High Level Driver based examples in S32K3 RTD 2.0.3. I will not encounter any errors when Update Code in the Spi_Transfer_S32K312_RTD203 example that I imported. You don't need to use the Pins tool of S32CT, just configure those pins in Port Configuration[MCAL].
Robin
NadipalliLTTS
Thanks for the reply first.
What if we use RTD 2.0.1?
We tried RTD 2.0.0, 2.0.1, shall we go for 2.0.3 ? our base version is installed with 2.0.1 version. we are working on one of the base version (already implemented by others).
also is there procedure to migrate RTD 2.0.1 to other versions ?
if all these above are not an issue, if we moved to 2.0.3 ? there will be any issue will takes place?
or still we can go for it?
Robin_Shen
If the project is received from others. Please check the S32K3 Build Version of that project. For example: I imported Spi_Transfer_S32K312 of RTD 2.0.1, there you will see the version:
Robin_Shen
Robin
