NXPS32k148_Ethernet communication with KSZ8061 daughter board
814件の閲覧回数
Milado
Hello ,
I'm using NXPS32k148 and KSZ8061 Ethernet daughter board to enable Ethernet communication with a PC or another device.
I'm using "lwip_s32k148" example but the communication doesn't work for now.
First of all I want to verify if my schematic is ok.
I'll attached the schematic of board.
Can you please confirm that the schematic is ok? or not?
Best regards;
Milad
2 返答(返信)
509件の閲覧回数
Azezur_Rehman
i am using mcp5775b bord with ksz8061 ic i want to print dynamic ip and mac address can any one give me example code
809件の閲覧回数
VaneB
Hi @Milado
In the following links are the schematics of the S32k148EVB:
S32K148EVB-Q176 Evaluation Board – REV A
S32K148EVB-Q176 Evaluation Board – REV B
I believe these would be useful for you.
B.R.
VaneB
