MCU SPI Configuration (MC3364)
Patrick_Pavle
Dear Community,
In MC33771x/MC33772x transformer and wire guide on the TPL network (nxp.com) and Isolated network high-speed transceiver (nxp.com) you see different application circuit.
In one there are 2 times MOSI and in the other MOSI and MISO are used. How is it correct?
How are SCLK_RX, CSB_RX and DATA_RX configured?
Is SCLK_RX -> "Slave SPI clock inputs" or "Master SPI clock output"?
Is CSB_RX -> "Slave select input" or "Master slave select output"?
best regards,
Patrick
PetrS
it should be MOSI for both SPIs. SCLK_RX, CSB_RX and DATA_RX are signals generated by MC33664, thus pins on MCU should be inputs and SPI configured as slave.
BR, Petr
Patrick_Pavle
Hello @PetrS,
do you have any data sheets on where this can be found?
best regards,
Patrick
PetrS
how SCLK_RX, CSB_RX and DATA_RX signals are generated will be explained within MC33664 datasheet and associated App notes. The usage of SPI on MCU side depends on MCU selected and its datasheet/Reference manual will explain this.
BR, Petr
