MCAL License Error
MCAL License Error
lb28
I am trying to configure the MCAL for the NXP S32K14W-Q064 board; EB Tresos is used as the MCAL configuration tool. I’ve downloaded the evaluation version of AUTOSAR 4.2 (S32K1XX_MCAL4_2_RTM_1_0_5)  from NXP. However, once loaded onto the EB Tresos software, the modules yield a “No License for module” error (attached). Any thoughts?
nxf78987
Hi lb28,
Did you install the license of S32K1XX_MCAL4_2_RTM_1_0_5 correctly?
And Did you install the EB Tresos version correctly with the S32K1XX_MCAL4_2_RTM_1_0_5 package (noted in the release note)?
If the installations are corrected, Could you try to re-install the S32K1XX_MCAL4_2_RTM_1_0_5?
Dan
jack_jin
I was in the same situation
nxf78987
Hello @jack_jin,
Did you download and install the latest license of the S32K1XX_MCAL4_2_RTM_1_0_5 package correctly?
Dan
