How to use S32 Design Studio for S32 Platform for files generated by Simulink
2,684 次查看
autics
I implemented the example of the link below in MATLAB/Simulink.
Is it possible to use the file generated by Simulink as a Build Project in the S32 Design Studio for S32 Platform program?
https://www.nxp.com/design/training/get-to-know-the-user-friendly-nxp-mbdt-for-application-developme...
2,217 次查看
autics
Thank you so much for the technical support.
I will get technical support from the link below for the unresolved issues.
https://community.nxp.com/t5/Model-Based-Design-Toolbox-MBDT/Why-does-it-work-well-in-the-S32DS-for-...
15 回复数
2,642 次查看
VaneB
Hi @autics
We have a model-based design toolbox for Matlab/Simulink. Please check this community site Model-Based Design Toolbox (MBDT).
Check the following threads. It has information related to the topic you might find useful.
Export generated projects in MBDT for s32k3XX
How to export Generated Code to S32 Design Studio IDE
B.R.
VaneB
2,612 次查看
autics
The project was created as below by importing XML as shown in the image above.
The problem is that the build area is not active as shown in the image below.
2,598 次查看
VaneB
Hi @autics
Check the following thread, it has information related to the topic.
The PROJECT by importing the .xml file into s32ds PA cannot be compiled, there is no C/C++ bulid.
2,591 次查看
autics
Thank you for your support,
but I haven't solved the problem yet.
I'm attaching my file.
2,556 次查看
VaneB
Hi @autics
Please verify if there are no spaces in the path where the toolbox is installed. According to what we have seen this should solve many issues.
2,478 次查看
autics
You were right.
The build icon has been activated as the space has been removed.
There is another problem as shown in the attached image below.
A build error occurs.
2,440 次查看
VaneB
Hi @autics
This topic has been discussed in other threads. Check them, it might be useful for you.
No Rule to Make Target error
No rule to make target
No rule to make target (MCU on Eclipse)
2,416 次查看
autics
Hi @VaneB
I selected a specific file and built it as shown in the image below.
A new error occurs.
2,386 次查看
VaneB
Hi @autics
The 35 only means line 35 in the makefile. There should be more output in the console log indicating errors/warnings...
2,330 次查看
autics
I'm so sorry.
I'm still not good at using the S32 Design Studio for S32 Platform 3.4.
The error is as shown in the image below.
How can I set it up in the attached image below?
2,319 次查看
VaneB
Hi @autics
This is usually caused by an incorrect location pointing, please verify the library location.
2,308 次查看
autics
Hi.@VaneB
S32 Design Studio for ARM Version 2.2  creates libm.a file and builds well.
However, libm.a file is not generated in program S32 Design Studio for S32 Platform 3.4
I'm sorry, but please support me one more time.
2,255 次查看
VaneB
Hi @autics
Try looking for the .a file directly into the Simulink files and copy the path. If the error persists, please help me by creating a new thread in the Model-Based Design Tools (MBDT) community. Here the responsible engineers will help you.
2,218 次查看
autics
2,395 次查看
autics
I just checked that the S32 Design Studio for ARM Version 2.2 program works normally for the same file.
However, I don't know if the S32 Design Studio for S32 Platform 3.4 program doesn't work as above.
