I want to measure RPM from a hall sensor signal using s32k144, how do i do that?
i have tried using the input capture block and FTM hall sensor block, didnt have much luck.
any help would be appreciated
Hi @mars1,
You can refer to MCSPTE1AK144 Development Kit Application Software
AN12435, 3-Phase Sensorless BLDC Motor Control Kit with S32K144
https://www.nxp.com/docs/en/application-note/AN12435.pdf
BR, Daniel
