How to config TJA1103 for S32K344 - T172
NamLS
I am currently working with S32K344 - T172, and on my board there is a TJA1103A transciver for Ethernet protocol. I want to know if special configuration is required for TJA1103A to use it or not?
+ If yes, where do I need to refer to the relevant information?
+ Otherwise just configure the basic port pins and clock for external signal to be able to use it normally?
Please respond at your earliest convenience.
Thank you!
#TJA1103A, #S32K3xx
VaneB
Hi @NamLS
The available ethernet examples for the S32K344 you can find it included in the RTDs that can be downloaded from S32K3 Standard Software -> Automotive SW - S32K3/S32M27x - Real-Time Drivers for Cortex-M and also, there is available a lwIP TCP/IP at S32K3 Reference Software -> Automotive SW - S32K3 - Stacks.
Regarding the TJA1103 information. This was already answered in this community post: TJA1103 with S32K3xx.
B.R.
VaneB
