How do I know how much RAM is being used in the S32K144?
1,155 次查看
jingfang
RAM = Data + Bss,How do I know how much RAM is being used in the S32K144 while the software is running?
S32K144 now restarts at unfixed point.
1,136 次查看
Senlent
这应该是没有的
1,145 次查看
Senlent
Hi@jingfang
1.you can refer to this chinese document,througth.
在KEIL下查看单片机编程内存使用情况
2.set print size formmat to Berkeley.
1,139 次查看
jingfang
从编译结果,可以看出大小,是想问问有没有函数,在运行时,可以直接读取ram占用的大小。
1,137 次查看
Senlent
这应该是没有的
