Hi Community,
I am working with C-RUN analysis in IAR Embedded Workbench IDE – Arm 9.50.3. The project in S32DS has been built successfully with IAR toolchain arm 9.50 and then migrated to IAR Embedded Workbench IDE. A fatal error occurs when rebuild all as below:
linker_flash_s32k341.icf is attached. Could you provide some advice?
Looking forward to your reply.
