Error "make***[hello.elf] Error 1"
3,179 次查看
ie703092
Good day, we have a problem that by joining FreeRtos along with other functionality such as Flextimer or I2C, we generate that error. Reading in some forums say that some are by the linker and others because the memory was consumed. The error that appears in the legend is the following "make *** [hello.elf] Error" We are using S32 studio for the evaluation board s32k144.#error #linker #s32studio
标记 (1)
3 回复数
2,872 次查看
jiri_kral
can you please share output from build console?
Jiri
2,872 次查看
ie703092
2,872 次查看
jiri_kral
actually - I mean build console - the very first tab. There should be some description related to error (for example missing header...).
Jiri
