Dose CSEc use quick write mode to update CSEc keys?
823件の閲覧回数
yaojianhang
HI, @lukaszadrapa
In S32K1xx reference manual CSEc chapter, it says interrupting a CSEc key update operation(due to power loss,reset....) whill leave the contents in an indeterminate state.
It seems that if CSEc update keys in quick write mode will solve the above problem, I am interested in S32K144, when update csec keys(located in EEPROM), how it actually works? write eeprom in quick write mode or normal write mode?
yaojianhang
タグ(2)
2 返答(返信)
779件の閲覧回数
yaojianhang
thanks for your reply.
789件の閲覧回数
lukaszadrapa
Hi @yaojianhang ,
we do not provide more details about the implementation. Mentioned comment about interruption of s CSEc key update is still valid. There's only one requirement mentioned in the reference manual (at CMD_LOAD_KEY command):
"Once a quick write is started, user must finish the entire
quick write activity prior to starting a LOAD_KEY
command."
Lukas
