S32DS V3.4导入的工程无法正确编译
Lica
S32DS V3.4导入的工程无法正确编译,即使故意在程序里写错,也会很快出现编译完成,故障为0。
jiri_kral
can you please share output from build console? There is probably some error message.
The build is not finished, the build didn't start at all.
Lica
16:01:21 **** Incremental Build of configuration Debug_FLASH for project XXX_12V40AH_S32K342 ****
make -j12 all
7 [main] make 4116 child_info_fork::abort: C:\NXP\S32DS.3.4\S32DS\build_tools\msys32\usr\bin\msys-iconv-2.dll: Loaded to different address: parent(0xE60000) != child(0xEE0000)
make: fork: Resource temporarily unavailable
"make -j12 all" terminated with exit code 2. Build might be incomplete.
16:01:23 Build Finished. 0 errors, 0 warnings. (took 2s.130ms)
jiri_kral
Lica
找到问题原因了,谢谢!
1、我安装了这个工具:arm-gnu-toolchain-12.2.rel1-mingw-w64-i686-arm-none-eabi.exe
2、并且添加到了环境变量。
就可以编译了。
