Data logging on SD card using S32K144
2,768件の閲覧回数
Mrudula
Hello @mariuslucianand @kerryzhou ,
I want to use a micro SD card for data logging with the S32k144 controller. I read your posts on https://community.nxp.com/t5/NXP-Model-Based-Design-Tools/SD-card-logging-for-S32K144-using-Simulink...
I have the fatfs files but I need help with the SD card communication using spi. I checked out Kerry's posts too:
It would be of great help if the header files were available because the following function and Macros have not been defined in the code:
  1. System_init();                (in main.c)
  2. spiInit();                         (in main.c)
  3. MMCCSD_CID();           (in diskio.c)
  4. MMC_CS_SET();           (in MMCCS())
  5. MMC_CS_SET();           (in MMCCS())
Macros in the SD card code:
  1. SD_TYPE_V2HC
  2. SD_Type
  3. SPI_S_SPTEF_MASK
  4. SPI_S_SPRF_MASK
  5. SPI0_BASE_PTR->BR
Mrudula
8 返答(返信)
1,663件の閲覧回数
Arjun47
hi Mrudula ,
My name is Arjun,
Can u plz help me for the same , if u got the SD card driver.
I am using free RTOS withs32k146.
Thanks in Advance.
1,643件の閲覧回数
kerryzhou
Please create your own question post, then our Auto MCU engineer will help you, thanks.
Kerry
1,511件の閲覧回数
Arjun47
Hi Kerryzou
Please help me to develop SDMMC card driver on S32k146, i am using free RTOS on s32 design studio
Thanks in Advance
Arjun
1,508件の閲覧回数
kerryzhou
Hi @Arjun47 ,
  Please create a new question post about it, then our auto mcu engineer will help you.
  I mainly support the I.MX RT product, thanks.
Kerry
1,482件の閲覧回数
Arjun47
ok
2,757件の閲覧回数
kerryzhou
Hi Mrudula,
  S32K144 should have the related SD card driver SDK, you don't need to use my post code, that is based on the baremetal.
   You can check the S32K144 SDK code at first.
Kerry
2,747件の閲覧回数
Mrudula
Hi @kerryzhou ,
I downloaded the sdk. I found the lpspi drivers however I could not find any sd card driver for S32K144. Examples are also not available for sd card.
Can you suggest a way to move forward?
Mrudula
2,723件の閲覧回数
kerryzhou
Hi Mrudula
   Now, I mainly support the RT and kinetis product, not the S32K144, so I also don't have your chip related driver.
   But if you want to refer to the Kinetis SPI SD card driver, I attach it for your reference.
  Wish it helps you!
   But you need to modify the related SPI driver to your own chip driver, you need to make sure the chip SPI operation is correct, then add the SD card init, write, read etc, then add the fatfs.
Kerry
