Clock FIRC & PLL settings
Dev15
Hi Team,
I'm using RTD 3.0.0, S32K312, SDK 3.5 version and trying to configure PWM channels. The core clock is set to FIRC and could see a warning.
Please help to resolve it.
Thank you
VaneB
Hi @Dev15
As you select FIRC as the clock source you need to disable the PLL as mentioned in the warning. the warning would not be a problem.
B.R.
VaneB
