The CAN masks are not functioning as they are expected to be.
Example: 0x73F should allow 500, 580, 540...but it allows only 500. Looking for an explanation for this behaviour and how can this be fixed
what code do you use? Do you set global or individual masking scheme? Did you set mask registers in freeze mode, before entering normal mode?
BR, Petr
