Break at address "0x20010000" with no debug information available in S32K312
jingfang
I use Jlink update code, run show :
the same code update PE in EVB is ok.
What kind of problem colud that be?
Senlent
Hi@jingfang
You can try to change the .s file suffix under the project to .S. I checked some similar answers, the possible reason is that GCC distinguishes the case of .s
https://blog.csdn.net/eastgeneral/article/details/84913318?spm=1001.2101.3001.6661.1&utm_medium=dist...
