Not able to load the Goldvip can-gw on eb tresos studio
980件の閲覧回数
Karthik_7
I have downloaded and installed below packages
1. EB tresos AutoCore for S32G3      2. GoldVIP for S32G3
followed the GoldVip manual for applying patch and copying MCAL_ext plugins.
but while importing it to the eb , it is asking to remove multiple plugins as some doesn't exits there .
kindly let me know where i can get the proper plugins supporting GoldVIP , how to proceed without any errors
833件の閲覧回数
Karthik_7
Hello!!!
Finally i am able to import the package
i removed the below mentioned link from EB installation directory EB\tresos\links
Since RTD and llce and macalExt modules are having same plugings i hope these where causing the error
8 返答(返信)
834件の閲覧回数
Karthik_7
Hello!!!
958件の閲覧回数
Daniel-Aguirre
Can you help us share a capture of the message you are seeing?
Please, let us know.
947件の閲覧回数
Karthik_7
Previously i had done a mistake while installing ,
now i followed, first installed eb then installed 4.0.2 HF02 now i am able to find the previous missing plugins but ended up here with error "Cannot load configuration Dio. Another module already created a configuration at /AUTOSAR/TOP-LEVEL-PACKAGES/Dio/ELEMENTS/Dio " asking me to remove those mcal drivers
925件の閲覧回数
Daniel-Aguirre
Was the project deleted from workspace after the plugins were correctly installed? Or is this the same project which was imported at the beginning?
We recommend reimporting the project, since the plugins were not correct and could have caused a misconfiguration.
921件の閲覧回数
Karthik_7
Yes , I deleted it , I had a zip backup so I tried re importing it , but ended up with above error
908件の閲覧回数
Daniel-Aguirre
Thanks for your feedback. Have you applied the following modifications to the plugins inside EB Tresos?
Where you should delete some plugins and replace others.
890件の閲覧回数
Karthik_7
Yes , I followed these setup, and did these recommended changes  after that , I closed the eb and workspace deleted work space and once again importanted package on eb  then i got these errors
891件の閲覧回数
Karthik_7
Yes , I did these recommended changes
