Hi NXP,
I wonder when the S32G runs Linux on core-A, Flex_CAN controller whether can receive an error frame?
If receive an error frame from CAN, how do I dump it out?
Solved! Go to Solution.
Hello, @Alex_mjl
Thanks for the question and sorry for the delay.
The Flex_CAN controller is able to receive error frames.
For dumping the frames, you may try the candump tools directly, from my experience, the following command could be used for your reference:
candump -l any,0~0,#FFFFFFFF
Hope it helps.
Best Regards
Chenyin
Hello, @Alex_mjl
Hope it helps.
Best Regards
Chenyin
