I'm having trouble proceeding with 'Light Up RGB LED Based On Real Time Drivers'
I'm working on S32G-VNP-RDB2-SW-UG document.
After I 'Check Configuration and update code' (page 16), there is no Siul2_Dio_ip_Cfg.h.
(I do Pins configuration and add GPIO Drivers)
After that, if i follow the documentation as it is, it seems that the error occurs because that file(Cfg.h) does not exist.
I am working on Ubuntu 18.04 and S32 Design studio's version is 3.4.
Could you let mo know how i can create/generate that configuration header file?
Hello David Na,
1. Could you check "Siul2_Dio" driver is added correctly?
2. Could you check Update Files as below and see if there is "Siul2_Dio_ip_Cfg.h"?
Yonghwi Lee
