S32K144 I2C
S32K144 I2C
1,006 次查看
wanglijun
I am using S32K144, about the I2C module, I pan not use DMA, and I want to disable the interrupt, using the polling mode.
Is it OK?
标记 (3)
896 次查看
Alexis_A
Hello wanglijun‌,
This approach has some inconvenience since you will need to wait until the transmission/reception is complete but this is not a rule and you can use it if the application permits it.
Alexis Andalon
