IGF driver in S32DS PA SDK 2.9.0 missing 'extern "C"' block
1,068 次查看
dan_teodorescu
The IGF driver offered in S32DS for Power Architecture SDK 2.9.0 is missing the `extern "C"` qualifier around the function declarations. This results in a linker error when the IGF code is called from C++ code, as follows:
igf_application.cpp:106: undefined reference to `IGF_DRV_Init(unsigned long, igf_config_t const*)'
Please add the missing qualifier around this block.
Thank you, Dan
965 次查看
cuongnguyenvan
Hi Dan,
Thank your for your report. This one will add in rtm release.
Thanks and best regards
Cuong
965 次查看
jiri_kral
Hi Dan,
thank you for report. I'll create bug ticket for that.
Jiri
