Gap between two buffers in SCLK I2S
1,188 次查看
Mohit_Manvar
I'm using S32K142 controller for I2S communication.
I configured I2S through SDK drivers and sending audio buffer continously.
below is  screenshot in which we are facing gap in SCLK and due to that other clocks are being disturbed.
configuration:
using following function to send data in infinite loop.
uint8_t I2S_DataBuff_u8[] = {0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA};
FLEXIO_I2S_DRV_MasterSendData(&I2SMasterState, I2S_DataBuff_u8, 32U);
please share solution , how can I continuous send data.
Mohit
10 回复数
1,157 次查看
danielmartynek
Hello @Mohit_Manvar,
It has been discussed here:
https://community.nxp.com/t5/S32K-Knowledge-Base/S32K3-FlexIO-I2S-Continuous-Transfer/ta-p/1692165
Unfortunately, we don't have such an example built with the SDK, but in principle, it is the same.
A baremetal example is attached.
1,152 次查看
Mohit_Manvar
Hi @danielmartynek ,
Thanks for sharing bare metal code.
I tried to import code and build but it is not building successfully. error is attached below.
additionally if Build for release it is building successfully.I tried to check issue for debug_flash mode but following issue it there
so I tried with S32Ds for ARM IDE but having same problem.
please share details how can I remove error.
Mohit Manvar
标记 (1)
1,138 次查看
danielmartynek
Hi Mohit,
In S32DS 3.5, create a new project (without SDK) and copy the cource code from the example.
It should work this way.
1,135 次查看
Mohit_Manvar
yes,It is now building.
but during executing code , it is automatically going to Default ISR from below line.
I'm using S32K144 EVB for debugging.
1,040 次查看
danielmartynek
Hi @Mohit_Manvar,
I haven't had the time to test it.
Is it fault exception?
Please implement HardFault_Handler() in the project.
https://community.nxp.com/t5/S32K-Knowledge-Base/Fault-handling-on-S32K14x/ta-p/1114447
1,032 次查看
Mohit_Manvar
I tried to check causing of fault and I got this.
please briefly explain where should I call fault handler in code and how can I use it?
if possible please configure at your side and revert me back.
Mohit
964 次查看
Mohit_Manvar
Hello experts,
please help out to resolve this open topic.
Mohit
909 次查看
danielmartynek
Hi @Mohit_Manvar,
I'm sorry for the delay. I see now that the project has been built for the first maskset of S32K144 where DMA clock could be gated in PCC[CGC]. This was removed on the current version of the MCU.
Just comment this line out:
// PCC->PCCn[PCC_DMA0_INDEX] |= PCC_PCCn_CGC_MASK;
821 次查看
Mohit_Manvar
I tried to comment out that line but at the end it is not giving output for I2S.
Does any other modifications needed?
output pins:
please suggest your thoughts.
Mohit
812 次查看
danielmartynek
Hi @Mohit_Manvar,
Unfortunately, we don't have the capacity to port and debug every example right now.
The examples are provided AS IS.
