s32k144 sCST
s32k144 sCST
3,080 次查看
veerajuvh619
Hi sir,
I am using s32k144 controller for that i am getting errors as
1. undefined reference to m4_scst_execute_core_tests
2. undefined reference to m4_scst_accumulated_signature
3. undefined reference to m4_scst_last_executed_test_number
how to solve this errors.
i also attached linker file also.
please provide documents related to sCST of s32k144.
Please provide the solution.
Veeraju V Hallikeri
标签 (2)
标记 (1)
2,902 次查看
lukaszadrapa
When you added SCST component, did you click on Generate Processor Expert Code?
Can you confirm the library is linked like this?
If this doesn't help, could you share your project?
Lukas
5 回复数
2,901 次查看
veerajuvh619
Hi sir
I didn't found "lib_m4scst.a" in properties of my project.
that means library is not included but i clicked on Generate Processor Expert Code.
How to add lib_m4scst.a file?
Veeraju V Hallikeri
2,902 次查看
lukaszadrapa
is "scst1.h" included in that *.c file?
Lukas
2,902 次查看
veerajuvh619
Hi sir,
Yes, I included "scst1.h" file.
Veeraju V Hallikeri
2,903 次查看
lukaszadrapa
Lukas
2,634 次查看
gururajtalewad
I need S32K144 sCST library file. can you please share it to. gururaj.talewad@in.bosch.com
