Hi sir,
I am using s32k144 controller for that i am getting errors as
1. undefined reference to m4_scst_execute_core_tests
2. undefined reference to m4_scst_accumulated_signature
3. undefined reference to m4_scst_last_executed_test_number
how to solve this errors.
i also attached linker file also.
please provide documents related to sCST of s32k144.
Please provide the solution.
Veeraju V Hallikeri
已解决! 转到解答。
When you added SCST component, did you click on Generate Processor Expert Code?
Can you confirm the library is linked like this?
If this doesn't help, could you share your project?
Lukas
Hi sir
I didn't found "lib_m4scst.a" in properties of my project.
that means library is not included but i clicked on Generate Processor Expert Code.
How to add lib_m4scst.a file?
Veeraju V Hallikeri
Lukas
