how to allocate an input section from library file to a custom output section?
1,971 次查看
zengxianke
arm gcc ld script
 .zxk {libxyz.a:x.o(.data.*)}>flash.
not work?
1,807 次查看
stanish
please try to add one leading asterisk character in front of the library name:
.zxk {
*libxyz.a:x.o(.data.*)
}>flash‍‍‍
Hope it helps...
Stan
1,807 次查看
zengxianke
Thank you so much. It WORKS!!!
