Writing ELF binary into MPC5748G Flash
3,499件の閲覧回数
bix010
I'm using S32 with PEMicro debugger to write my compiled ELF into the flash of a MPC5748G LCEVB.
For debugging reasons, I also dumped out the full 6MB contents of user application flash. However, I can't find my ELF file in the dumped binary. The ELF magic number can't even be found.
How does S32 copy ELF binaries into flash?
Thanks!
3 返答(返信)
3,372件の閲覧回数
bix010
Hi Jiri,
Thanks for your reply. Am I correct to say that S32DS discards the ELF headers and only copies the necessary binary sections into their respective physical memory addresses?
3,372件の閲覧回数
jiri_kral
yes, you are right.
Jiri
3,372件の閲覧回数
jiri_kral
S32DS gets from elf raw binary data and write it into flash memory. Elf file is used for symbols and source code location.
Jiri
