The customer is Deeproute. customer try to use the S32DS 3.1 to debug issue with can_pal example. the error log:
Error in services launch sequence PEmicro GDB Launch Failure : The GDB Server was not able to establish a connection to the target processor. Please check your connections and power. Verify that the launch settings in the Debug Configuration are accurate.
I try to use different example, the result is same.
best regards
deqing.liu
已解决! 转到解答。
Hello Jiri,
I solved the isue. I just take off the SD card.
I think you need to upgrade the S32 Design Studio Platform Tools Package and S32V2XX development package.
best regards
deqing.liu
I tried your scenario - and ended in the same state. But mine issue is related to some PE Micro issue. It looks that firmware in PE Micro Multilink can't be updated - for some reason:
Are you facing the same issue?
Jiri
