Default Periodicity To Send Lin Frame From Slave To Master
1,607件の閲覧回数
itsnewforme
Hi, I'm using NXP Lin stack with S12ZVML64 MCU as Slave. I want to know what is the default Time period that is used in the stack to send a LIN frame from Slave to Master
Thanks in advance.
タグ(2)
1,597件の閲覧回数
danielmartynek
Hi @itsnewforme,
In the LIN protocol, a slave node sends a message in response to a request from the master node. The frequency of these messages depends on the configuration of the master.
In the installation directory of the stack, please have a look at:
LIN_User_Manual, Section 4.6.3 Timer for LIN schedule execution.
There is an example.
Thank you,
BR, Daniel
