While configuring the registers of T1042 for the DDR memory controller, i encountered a field "UNQ_MRS_EN" in the DDR_DDR_SDRAM_CFG_2 register and i am unable to comprehend what does it mean. Can anybody please explain what is it for and when to use it?
Please refer to the QorIQ T1040 Reference Manual, 14.4 DDR Memory Map/Register Definition.
If DDR_DDR_SDRAM_CFG_2[UNQ_MRS_EN]=0 then for all chip selects data from the following MODE registers will be used:
DDR_DDR_SDRAM_MODE
DDR_DDR_SDRAM_MODE_2
DDR_DDR_SDRAM_MODE_9
DDR_DDR_SDRAM_MODE_10
If DDR_DDR_SDRAM_CFG_2[UNQ_MRS_EN]=1 then individual data from the following MODE registers will be used:
for CS0:
DDR_DDR_SDRAM_MODE
for CS1:
DDR_DDR_SDRAM_MODE_3
DDR_DDR_SDRAM_MODE_4
DDR_DDR_SDRAM_MODE_11
DDR_DDR_SDRAM_MODE_12
for CS2:
DDR_DDR_SDRAM_MODE_5
DDR_DDR_SDRAM_MODE_6
DDR_DDR_SDRAM_MODE_13
DDR_DDR_SDRAM_MODE_14
for CS3:
DDR_DDR_SDRAM_MODE_7
DDR_DDR_SDRAM_MODE_8
DDR_DDR_SDRAM_MODE_15
DDR_DDR_SDRAM_MODE_16
Could you please elaborate when to enable this bit and when to clear? Thank you!
It is up to the board designer.
what information does the board designer need to know before setting/clearing this bit?
