Dear Sir/Madam,
I would like to get some information regarding recently discovered vulnerability CVE-2022-3643 which is scored as CRITICAL. Are there any plans to look into the issue on NXP platform? Could you confirm if your drivers are or are not affected?
I'm currently using kernel available under this location: qoriq-components/linux - Linux Tree for QorIQ support (codeaurora.org) with FSL_SDK_DPAA_ETH enabled, so in fact I'm using an SDK driver.
Kris
