Is there an example of USB device firmware (if possible for the FDRM K22F devkit) that directly uses Processor Expert's USB_LDD?
None of the examples that I found are based on Processor Expert's USB_LDD. They are usually higher-level examples...
Just something simple that demonstrates USB-attach and chapter 9 processing would be great!
Bruno
解決済! 解決策の投稿を見る。
Hello Bruno,
The MK22FN512 derivative support is available in the following service pack (it can be used for KDS 2.0.0 too):
Adds support for the MK22FN128, MK22FN256, MK22FN512, MKV31F128, MKV31F256, and MKV31F512 derivatives
Marek Neuzil
Hello Bruno,
There is not any USB demo example on FRDM K22F board but there are available USB_LDD demo examples on different boards, see for example
KDS 2.0.0:
KDS_2.0.0\eclipse\ProcessorExpert\Projects\Kinetis\ProcessorExpert\TWR-K70FN1M\USB_MS_Device - this project demonstrates use of USB_LDD component in a device mode as a mass storage device (FLASH DISK).
CW MCU 10.6.x:
CW MCU v10.6\MCU\CodeWarrior_Examples\Processor_Expert\Kinetis\TWR-K21F120M\USB_MS_Device - this project demonstrates use of USB_LDD component in a device mode as a mass storage device (FLASH DISK).
CW MCU v10.6\MCU\CodeWarrior_Examples\Processor_Expert\Kinetis\TWR-K70FN1M\USB_Mass_Storage_Device -this project demonstrates use of USB_LDD component in a device mode as a mass storage device (FLASH DISK).
CW MCU v10.6\MCU\CodeWarrior_Examples\Processor_Expert\Kinetis\TWR-K70FN1M\USB_AudioSpeaker - this project demonstrates use of USB_LDD component in a device mode as a audio speaker device (sound card).
PExDrv V10.4.x
PExDrv v10.4\eclipse\ProcessorExpert\Projects\Kinetis\ProcessorExpert\TWR-K70FN1M\USB_MS_Device - this project demonstrates use of USB_LDD component in a device mode as a mass storage device (FLASH DISK).
Marek Neuzil
Hi Marek
After installing KDS V2.0, and installing the KSDK module in KDS it seems that the MK22FN512VLH12 processor is not supported in KDS anymore. The project I was working on is not working anymore.
Is there something that I missed?
It would be great if there was a published (simple) set of steps to install or upgrade KDS, find the latest patches, install them...etc.
Bruno
Hello Bruno,
Marek Neuzil
Thanks Marek
Hi Marek
I had not noticed that there was a new version of KDS.
I will look at this.
Thanks!
Bruno
