About MPC8247's PSDMR, will there be any risk, if RFRC is 1 clock longer than its theoretical value。
linding
About MPC8247's PSDMR.
Will there be any risk, if RFRC is 1 clock longer than its theoretical value。
alexander_yakov
RFRC defines "earliest" timing to issue activate command after refresh command. I.e. after refresh is issued, next activate command can be issued "not earlier than". I do not see anything wrong, if this parameter will be set to +1 from theoretically calculated value.
Alexander
alexander_yakov
Alexander
linding
Thanks very much for your answering.
