NXP team.
Hello! I have the following questions about the MWCT2xx3A chip:
Do you have an SDK related to this chip? Currently, I have WCT in my hands WCT_ 15WAUTO13_ GA2.1 routines, however, I found that most of them are directly operated on related registers.
Solved! Go to Solution.
Hello Niuyanlin,
I am pleased to contact you again.
As far as I know, we do not have any SDK available for such device. In this case, I highly recommend contacting your local distributor for further information.
I hope this information helps.
David
Hello Niuyanlin,
I hope all is great with you. Thank you for using the NXP communities.
I do recommend reviewing the document from the link below, at chapter 7 you may find further information about the CodeWarrior and related projects.
https://www.nxp.com/docs/en/user-guide/WCT101XV10AUG.pdf
You may find the following post useful as well.
David
Hello Niuyanlin,
David
