MFS5600 and MPF5020 OTP Programming
ThorVic
So we initially plan on doing our OTP programming process during production for these 2 parts. We noticed on the newly released datasheets (March/April 2024), there is a new note regarding OTP programming that was not mentioned in the older datasheets. So is it mandatory to have only NXP or recommended third party to program the device for production run?
diazmarin09
Hello ThorV,
I hope all is great with you. Thank you for using the NXP communities.
Correct. In this case, I do recommend contacting your local NXP sales representative for further information.
I hope this information helps.
David
